Quicklinx: | 8LMMWS00 |
Mfr#: | 8228B011AA |
Capture smooth movies and sharp shots with 20x zoom
The ideal compact for every family occasion, the PowerShot SX270 HS has a powerful 20x zoom to get you closer to the action, advanced Full HD movies and HS System with DIGIC 6 for exceptional results.
20x zoom, 25mm wide lens
HS System: 12.1 MP CMOS, DIGIC 6
Intelligent IS, Enhanced Dynamic IS
Full HD (60fps)
7.5 cm (3.0") PureColor II G LCD
Hybrid Auto; Smart Auto
Manual, Av and Tv modes
High-speed shooting
Optional 40m Waterproof Case
Fit more in the frame with 25mm or get extremely close to distant subjects with 20x optical zoom. Enjoy approx. double zoom power with ZoomPlus - an advanced zoom technology with more visible detail and sharpness than conventional digital zoom. The compact body means you can capture every precious memory wherever you go.
HS System excels in low light allowing you to capture the real atmosphere of the moment without flash or a tripod. Advanced DIGIC 6 processing and a high sensitivity 12.1 Megapixel CMOS sensor give exceptional image quality in all situations with up to ISO 6400.
Intelligent IS combats camera shake, so all your photos and videos are sharp and detailed even at full zoom or in low light. Enhanced Dynamic IS ensures spectacular steady and realistic movies by powerfully compensating for a much wider range of user movements.
Full HD movies (60fps)
Use the movie button to instantly record smooth, stunningly realistic Full HD (1080p) movies at 60fps in stereo with optical zoom. MP4 support allows easy playback and sharing on portable devices.
A large, durable, high quality LCD screen with excellent visibility offers effortless menu navigation, lets you frame and view shots with ease and makes sharing them a pleasure.
Hybrid Auto, Smart Auto
Effortlessly shoot great photos or movies with Smart Auto, which selects optimal settings from 58 variables (21 in movies). Hybrid Auto lets you take photos with Smart Auto and also captures a 4 second movie clip before each shot - combining them into a fun HD (720p) movie.
Experiment with different effects using Manual modes (Tv, Av and M), which give you creative control over shutter speed and aperture.
High-speed shooting
Capture stunning fast action with High-speed Burst or slow it down spectacularly with Super Slow Motion Movie.
