You can capture sharp detail in even the most challenging situations thanks to the bright f/1.8-2.8 lens, which lets a lot of light to reach the sensor. With a 4.2x optical zoom (24 - 100mm) it is ideal for both wide-angle photography and getting closer to your subjects. Shoot stunning portraits with beautiful perspective and background blur using the wide aperture at full zoom.
Beautiful Bokeh
The term 'Bokeh' comes from a Japanese word that refers to the quality of the out-of-focus parts of an image. The PowerShot G7 X uses a nine-bladed lens aperture to produce smooth background blur and virtually circular out-of-focus highlights. Create beautiful 18-ray starburst effects in scenes with strong highlights.
Sensor
The 1.0-type CMOS sensor offers you improved low light performance without compromising the compactness of the camera. It uses a light-sensitive area that is nearly 3 times larger than that of 1/1.7-type sensors, providing increased light sensitivity, reduced noise, (especially at high ISO) and a wider dynamic range. It also gives you greater creative flexibility with a shallower depth of field for professional looking out of focus backgrounds.
HS System
Day or night your images will be just as you remember them. Canon's HS System - with DIGIC 6 and a large 1.0-type, 20.2 MP CMOS sensor - gives you exceptional image quality and excels in low light. So it's easy to capture the real atmosphere of the moment without flash or a tripod.
Sharp results every time
There's no need to worry about camera shake ruining your results thanks to an intelligent optical Image Stabilizer. This camera automatically adapts and ensures sharp, detailed photos and videos even if you're shooting at full zoom or handheld in low light. Plus your movies will be spectacularly steady thanks to 5-axis movie stabilization.
Capture the moment
When things are changing fast, the PowerShot G7 X lets you work quickly, capturing 6.5 frames a second to ensure you always capture that special moment. What's more you can carry on shooting at this speed up to 692 frames. Catch the action with high-speed 31-point AF. The 31-points cover a large area of the frame, with a confirmation of the chosen AF points.
Intuitive touch screen
Enjoy superb viewing and flexible framing. A high-quality LCD tilt-up touchscreen, with 1,040k dot resolution, uses sRGB color reproduction for excellent color accuracy, image clarity and contrast. The touch interface enables more intuitive control and adds a range of useful functions such as Touch AF.
Make movies with the personal touch
Making stunning movies is easy. With one touch of a button you can shoot smooth, realistic Full HD 60p movies in stereo, recorded in the widely compatible MP4 format. Achieve perfect focus with the MF Peaking function and explore your creativity using manual movie control.
Easy creativity
Capture amazing images with ease. Shoot stunning starry nightscapes, star trails or star time-lapse movies with Star Mode. Use HDR to capture high contrast scenes without a tripod or Background Defocus to achieve beautiful, SLR style background blur. Effortlessly create a fun HD (720p) movie summary of all the day's shots with Hybrid Auto.
Canon PowerShot G7 X - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.2 Megapixel
Lens System
Zoom lens - 4.2x zoom - 8.8 - 36.8 mm - f/1.8-2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery - 1250 mAh (included)
Composite video/audio, HDMI, USB 2.0
10.3 cm x 4.04 cm x 6.04 cm
304 g
Sensor Resolution
20.2 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
20,200,000 pixels
Effective Sensor Resolution
20,900,000 pixels
Optical Sensor Size
1.0"
ISO (Max)
12800
Optical Zoom
4.2x
Digital Zoom
4x
Image Processor
DIGIC 6
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, PictBridge support
Auto Focus
AiAF
Auto Focus Points (Zones) Qty
31
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG, RAW, RAW + JPEG
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 800, ISO 125, ISO 400, ISO 200, ISO 320, ISO 640, ISO 500, ISO 250, ISO 1600, ISO 6400, ISO 3200, ISO 1000, ISO 1250, ISO 2000, ISO 2500, ISO 4000, ISO 5000, ISO 12800, ISO 10000, ISO 8000, ISO auto (125-12800)
Portrait mode, fireworks, Underwater, soft background, snow, super vivid, poster effect, fisheye effect, miniature effect, toy camera effect, soft focus, monochrome, Dynamic Range (HDR), creative shot, star nightscape, star trails, handheld night scene, star portrait
Built-in 1/8 neutral density filter, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode
Red-Eye Reduction
AF illuminator, flash +/- compensation
Effective Flash Range
0.5 m - 7 m (wide lens) , 0.4 m - 4 m (tele lens)
Additional Features
Continuous Shooting Speed
6.5 frames per second, 4.4 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, GPS via mobile, YouTube Direct Upload
RAW 5472 x 3648 , RAW 4864 x 3648 , RAW 5472 x 3080 , RAW 3648 x 3648 , RAW 3648 x 2912 , JPEG 4320 x 2880 , JPEG 3840 x 2880 , JPEG 4320 x 2432 , JPEG 2880 x 2880 , JPEG 2880 x 2304 , JPEG 2304 x 1536 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 1536 x 1536 , JPEG 1536 x 1232 , JPEG 720 x 480 , JPEG 640 x 480 , JPEG 720 x 408 , JPEG 480 x 480 , JPEG 480 x 384
Video Capture
AVI - 1920 x 1080 - 60 fps , AVI - 1920 x 1080 - 30 fps , AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps , iFrame - 1920 x 1080 - 30 fps , AVI - 1920 x 1080 - 30 fps - Time-Lapse mode , AVI - 1920 x 1080 - 15 fps - Time-Lapse mode , AVI - 1280 x 720 - 6 fps - Miniature Effect , AVI - 1280 x 720 - 3 fps - Miniature Effect , AVI - 1280 x 720 - 1.5 fps - Miniature Effect
