The PowerShot A2600 is a stylish compact camera that makes capturing amazing images simple without compromising on quality. Harness the power of the 16.0-megapixel sensor and DIGIC 4 image processor and record precious moments with incredible detail and responsive performance. A 5x optical zoom with 28 mm wide-angle lens brings you closer to the shot even as you fit more in your frame. Smart AUTO with 32 predefined shooting situations is activated with the single push of a button, so every shot you take is a smart shot, for results you'll love to share. It's also easy to capture brilliant 720p HD with a simple press of the dedicated movie button. The PowerShot A2600 will keep on shooting with the new eco mode, which preserves power so you get more shots per charge. The versatile PowerShot A2600 can get you the shots you want, simply.
