Quicklinx: | 8JDRWS00 |
Mfr#: | 6992B008AA |
High productivity, powerful Office All-In-One with Wi-Fi and XXL ink option
Powerful and productive 5-ink All-In-One offering XL and XXL ink options, Wi-Fi, Ethernet and 35-page 2-sided ADF. Advanced media handling with 250-sheet paper tray, 2-sided printing and Direct Disc Print.
Powerful and productive All-In-One
This premium, network-ready All-In-One delivers high productivity that everyone can share. Wi-Fi and Ethernet connectivity enable you to print, scan, copy and fax from virtually anywhere in the office or at home. Apple AirPrint support lets you print directly from iPad and iPhone.
Automatically scan, copy or fax large double-sided documents using the fully-integrated 35-page 2-sided Automatic Document Feeder. A high capacity 250-sheet tray means you spend less time loading paper, while automatic 2-sided printing reduces the amount of paper you use. Double front paper cassettes mean you can conveniently have two media types loaded at once, plus you can print directly onto printable discs using Direct Disc Print.
Economical, single ink tanks
For greater economy, this All-In-One features 5 single inks, so you only need to change the colour that runs out - making printing more efficient. Optional cost effective XL and XXL inks allow for more pages to be printed than a standard ink, so need replacing less frequently - ideal if you print a lot. XXL cartridge can print up to 1000 pages.
High quality, fast performance
Canon's FINE technology, with minimum 1pl ink droplets, delivers up to 9600dpi print resolution for amazingly detailed colour photos and images. Enjoy high print speeds of 15ipm mono or 10ipm colour. Print a photo-lab quality 10x15 cm borderless photo in approx. 21 seconds or copy an A4 page in just 12 seconds.
PIXMA Cloud Link
Print Google Docs, Gmails, photos and PDF attachments from virtually anywhere using Google Cloud Print. Produce calendars, download stationery and other templates direct from the PIXMA Cloud. Get more from your printer and print directly from the Internet. Print photos in seconds from CANON iMAGE GATEWAY or Google's Picasa online albums without a PC.
Smartphone and tablet ready
Canon's Easy-PhotoPrint app provides the flexibility to print from, or even scan to, your mobile devices wherever you are in the office. With Apple AirPrint support, you can also print photos, emails, web pages and other documents direct from your iPhone, iPad and iPod touch.
User-friendly operation
A large 7.5cm colour TFT display makes it easy to view selected functions and preview images. The Dual Function Panel features LED-lit dual-purpose keys. These keys change appearance according to the mode selected, simplifying feature navigation.
