| Quicklinx: | 7ZK5WS00 |
| Mfr#: | 5783B008AA |
PIXMA MX435 with built-in Wi-Fi and ADF, this stylish All-in-One fits perfectly in the home office with it's quick print speeds. Compact design with FastFront.
The Wi-Fi All-In-One that handles everything with ease
Designed for anywhere
This compact All-In-One, with sleek all-black design and built in Wi-Fi connectivity, is perfectly placed to help you print, copy, scan and fax - from wherever suits you best.
High quality
Canon's FINE ink technology, with minimum 2pl ink droplets and print resolution up to 4800 x 1200 dpi, delivers glorious colours and crisp text - ideal for business documents or photos.
Productivity boosting 30-sheet ADF
Scanning, copying or faxing large documents is quick and easy for more productive working, thanks to a fully-integrated 30-sheet Automatic Document Feeder. The scan and save to a compact pdf feature is ideal for archiving. Additionally, you can scan-to-email for efficient workflow.
Faster performance
Enjoy print speeds of 9.7 ipm mono or 5.5 ipm colour. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 21 seconds. Quick Start means this All-In-One is ready to go seconds after switching on.
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page.
Space-saving design and easy-to-use
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to `warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions virtually straight away.
Fast, cost-effective faxing
Super G3 faxing is fast and reliable. Incoming faxes can be saved as a PDF file to USB memory for viewing and keeping a digital record. You can also reduce costs as you can choose what to print.
Intelligent software
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimising the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security, MP Navigator EX adds passwords to PDFs restricting who can edit or print sensitive documents.
Remote printing from iPhone or iPad
Support for Apple AirPrint enables you to print directly to the PIXMA MX435/MX434 from a compatible mobile device.
