| Quicklinx: | 7ZK6WS00 |
| Mfr#: | 5781B008AA |
The All-In-One that handles everything with ease
PIXMA MX375 is an All-In-One with fax that delivers quality prints. With a built-in 30-sheet ADF, full suite of software it's both versatile and affordable. Compact design with FastFront.
Quality results for home and office
This affordable All-In-One lets you copy, print, scan and fax with ease. Canon's FINE ink technology, with microscopic ink droplets, plus a resolution of 4800 x 1200 dpi ensures quality printing everytime. From vivid and glossy graphics to business documents of outstanding clarity, the printer is ideal for use at home or in a small office.
Productivity booster
For maximum productivity, a fully-integrated 30-sheet Automatic Document Feeder makes scanning, copying or faxing of large documents easy and fast.
Do more for less, faster
Enjoy print speeds, of 8.7 ipm in mono or 5.0 ipm in colour. A 10x15 cm borderless photo is printed in approximately 46 seconds, while an A4 page copies in just 23 seconds. Canon's Dual Colour Gamut Processing technology enables great quality photocopying with no waiting around.
Value for money
For further savings you can print more for less, with the high yield Canon XL cartridges, which offer 50% lower cost per page.
Space-saving design and easy-to-use
The compact FastFront design means paper and ink cartridges can be loaded from the front of the printer - making it easier to fit into a busy work space. Quick Start functionality means there is no need to wait for the printer to `warm up'. Operation is almost instantaneous from the moment the power is switched on, ensuring that the user can perform actions almost straight away.
Fast faxing
Super G3 faxing is fast and reliable. The PIXMA MX375 can send faxes directly from the PC without printing the document first. For advanced security you can prevent users accidentally sending faxes to the wrong number.
Intelligent software
Take control of your web printing, easily combining content from several websites with Easy-WebPrint EX. Automatically optimising the quality and legibility of scanned documents is simple with Auto Document Fix. For additional security MP Navigator EX adds passwords to PDFs that restrict who can edit or print sensitive documents.
All-In-One with fax and 30-sheet ADF
Up to 4800dpi, min. 2pl quality
ISO ESAT 8.7 ipm mono/5.0 ipm colour
ISO A4 Copy: 23 seconds
Easy-WebPrint EX for efficient web printing
Auto Document Fix enhancement
Full HD Movie Print
