This high-performance 5-ink All-in-One has Wi-Fi and touch screen making it easy for you to print your documents and photos direct from smart devices as well as access cloud storage services.
Print, copy and scan with just a few swipes of the large touch screen using this high-performance home All-In-One
Experience a touch of class. Print, copy, scan and access the cloud with simple and smartphone-like control using this high-performance home All-In-One. A large 7.5 cm colour touch screen makes it quick and easy to navigate menus, select functions, preview images and use cloud services.
Print superb photos direct from memory cards and cameras with Canon's FINE technology, 4,800dpi print resolution and 5 single inks
Easily print superb photos, packed with deeper blacks, more vivid reds and high levels of detail, directly from memory cards and compatible wireless cameras - thanks to 5 single inks, Canon's FINE technology and up to 4,800dpi print resolution. ISO ESAT speeds of 15.0 ipm mono and 9.7 ipm color deliver a 10x15 cm borderless photo in around 41 seconds.
Quickly and effortlessly print and scan from smart devices with the Canon PRINT app and Wi-Fi Direct
Simply download the Canon PRINT app and you can effortlessly print and scan using your smartphone or tablet, and directly access cloud services. There's no need for a wireless router, internet connection or password with Wi-Fi Direct mode, which creates an ad hoc wireless network
Experience the creative freedom of cloud printing and scanning with enhanced PIXMA Cloud Link
With enhanced PIXMA Cloud Link you can print photos in seconds from Instagram Facebook and Flickr and print documents from popular cloud services, such as GoogleDrive, OneDrive and Access to SlideShare . Easily upload scanned documents and photos to GoogleDrive, OneDrive and OneNote.
Only change the color that runs out with individual ink tanks; save using optional XL inks and auto 2-sided printing
Enjoy minimum waste and maximum savings. You only need to change the color that runs out thanks to individual ink tanks. Plus you can print more pages for your money using optional XL inks and save on paper with auto 2-sided printing.
2 on 1, 4 on 1, fit to page, Frame Erase Copy, photo mode, Borderless copy
Printing
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering)
Max Printing Resolution
4800 x 1200 dpi (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 9.7 ipm (colour)
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Printing: up to 15 ipm - B/W , Printing: up to 9.7 ipm - colour , Printing: 41 sec (10 x 15 cm (4"x6")) - photo , Scanning: 19 sec (A4) - colour , Copying: up to 7.7 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista SP2, MS Windows 7 SP1, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.7.5 - 10.10, Windows 10
Software Included
Drivers & Utilities, Canon Full HD Movie Print, Canon My Image Garden, Canon Print Service Plug-in for Android, Quick Menu, MP Driver including Scanning Utility
AC 120/230 V (50/60Hz)
12 Watt
Power Consumption Standby
1.5 Watt
Power Consumption Sleep
0.2 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
18 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
