Connect easily with smart devices using this compact Canon PIXMA MG3650 Wi-Fi all-in-one. Enjoy fast, high-quality print, copy and scan with 2-sided printing.
Connect, print, copy and scan the way you want with this Wi-Fi all-in-one that delivers fast high-quality, borderless prints
Effortlessly print stunning borderless photos packed with high levels of detail, plus professional looking documents with sharp text - thanks to Canon's cartridge system and up to 4,800 dpi print resolution.
Effortlessly print and scan using smart devices- no Internet required with built-in access point mode
You're smartphone ready and so is this printer. You can print and scan using your smartphone or tablet. Built-in access point mode creates an ad hoc wireless network - so you can print and scan directly without having to join a Wi-Fi network or use the Internet.
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 4-ink
Max Copying Speed
2.7 ppm (colour)
Max Printing Speed
Up to 9.9 ipm (mono) / up to 5.7 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, matte photo paper, high resolution paper, luster paper, semi-gloss photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, PIXMA Cloud Link, scan to Cloud, access point mode
AC 120/230 V (50/60Hz)
44.9 cm x 30.4 cm x 15.2 cm
5.4 kg
Enclosure Colour
Multifunction printer
Printing Technology
Ink-jet - colour
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Enclosure Colour
Copying
Max Copying Speed
2.7 ppm (colour)
Maximum Copies
21
Copying Features
Fit to page
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
