The PIXMA iP3600 is a compact, affordable home photo printer with class-leading specification that delivers superior photo lab quality prints.
The PIXMA iP3600 features crisp text printing thanks to a dedicated black pigment ink cartridge, making it appropriate for all kinds of web and document printing.
All 5 Single Inks can be replaced individually, minimizing unnecessary ink wastage. A smart LED indicates when a cartridge is running low or needs replacing.
Two paper trays enhance media flexibility, allowing both photo paper and plain paper to be loaded at the same time without having to swap them manually. Digital camera users will also benefit from the ability to print directly from their camera without a PC using PictBridge. If you prefer to hook the printer up to your PC, a Hi-Speed USB interface enables the fast transfer of information.
