The MF515x black and white A4 laser Multifunctional printer is ideal for enterprise workgroups that want fast, professional-quality output capabilities in a fully featured compact device tailored for flexible working.
Small enterprise workgroups in search of a big productivity boost will find the MF512x A4 black and white laser multifunctional printer an unbeatable choice. It boasts the powerful features and capabilities of a large office multifunctional printer but in a compact device that's easy to accommodate in small spaces. Busy teams will appreciate its fast, high-quality printing and copying at impressive speeds of up to 40ppm. The color touch screen enables easy operation for all levels of user; while a 600-page paper capacity and Quick First-Print from start-up help your teams work more efficiently. Sensitive documents are protected using the Secure Print function that PIN-protects documents when printing from a PC or mobile device.
Flexible working
Thanks to the MF512x's extensive support for Apple AirPrint (iOS) and Mopria (Android), your workgroup can print from any enabled device. They can also access a wide range of advanced features with the Canon PRINT Business app and can connect the device to a Google Cloud Print account in seconds.
Enhanced document sharing
Busy teams can gain welcome flexibility thanks to the MF512x's MF Scan Utility (for PCs/laptops) and Canon PRINT Business app (for mobile devices) that enables seamless cloud integration. Teams can use their favorite cloud storage services to capture, digitize and share documents at any time and from any place.
Smart networking capabilities
With a host of flexible networking capabilities, the MF512x makes a perfect addition to your enterprise network. Alongside Wi-Fi and Ethernet connectivity, full support for PCL5e/6 and Adobe PostScript printer languages enable easy integration into your device fleet. Managed print services teams will find the remote service capabilities and support for Canon's uniFLOW output system make for hassle-free management.
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Standard Media Capacity
600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 500 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ipm (A4) - B/W duplex , Copying: up to 40 ppm (A4) - B/W , Copying: up to 20 ipm (A4) - B/W duplex , Scanning: up to 33 ipm - B/W , Scanning: up to 13 ipm - B/W duplex , Scanning: up to 11 ipm - colour , Scanning: up to 7 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, ARP, MAC address filtering
Operating System Support
Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2, Windows 10
