MAXIFY MB5350 is a powerful All-in-One for the most demanding small office environments. It features fast 2-sided printing and scanning, 500-sheet paper capacity, usage controls plus smartphone and cloud connectivity.
Be productive and stay connected with this robust high-speed all-in-one designed for demanding small office environments. With Wi-Fi and Ethernet connectivity plus professional print quality - and usage controls for added peace of mind - this is the perfect office companion.
High-speed document printing
Never wait around for your business documents again. Fast A4 document ISO print speeds are combined with a similarly rapid Quick First Print time.
Business quality
Dual Resistant High Density inks produce sharp text and vivid colors. These pigment inks have outstanding fastness - so they won't fade over time - and are marker and friction resistant too making them perfect for high quality business documents.
Added productivity when needed
Make light work of every task including multi-page scanning and copying thanks to two 250-sheet paper cassettes, an integrated single pass 2-sided 50-sheet ADF and a large color touch screen. Effortless, double-sided printing is also available for added professionalism and lower paper consumption.
With MAXIFY Cloud Link you can print from popular cloud services like Evernote, Dropbox, OneDrive or Google Drive directly from the printer screen or from a smartphone using the MAXIFY Printing Solutions app. Scan to email, Apple AirPrint and Google Cloud Print functions are also supported.
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Standard Media Capacity
500 sheets
2 x paper cassette - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 275 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 23 ipm (A4) - B/W , Printing: up to 15 ipm (A4) - colour , Copying: up to 21 ipm - B/W , Copying: up to 10 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista SP1, MS Windows XP SP3, MS Windows Server 2008, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows RT, Android, iOS, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities, Canon Easy-WebPrint EX
AC 120/230 V (50/60Hz)
31 Watt
Power Consumption Standby
1 Watt
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (pigmented cyan) , 1 x ink tank (pigmented magenta) , 1 x ink tank (pigmented yellow)
