Are you looking for a dedicated scanning solution with great quality, versatility and a compact design? Then the CanoScan LiDE110 color image scanner is sure to impress. The CanoScan LiDE110 features the quality, speed and ease of use you need with a maximum resolution of 2400 x 4800 (optical) dpi for excellent scanning quality for both photos and documents.
You'll immediately notice how easy the CanoScan LiDE110 is to use. Auto document fix automatically delivers beautiful, easy-to-view scans by advanced image analysis and area-by-area data correction while the auto scan mode feature automatically detects the original and saves its appropriate settings. Need to share information? The CanoScan LiDE110 has four EZ buttons that enable you to scan, copy, email or create a PDF faster than ever.
You'll also be able to proudly join the generation green initiative as its one USB cable for data and power provides lower power consumption.
