The LEGRIA mini X with Wi-Fi offers pure CD quality audio and a wide dynamic range. The unique combination of ultra-wide angle lens, built-in stand and vari-angle LCD gives you the power to create movies that sound as good as they look.
Get a wider perspective and capture more of every scene using the ultra-wide angle lens with a 160° angle of view for Full-HD movies and 170° for stills. With its unique compact design, the LEGRIA mini X is extremely portable - so you can carry it everywhere you go.
Easily frame yourself and shoot from a wide variety of angles using the innovative 6.8 cm (2.7") vari-angle capacitive touch screen LCD - flip it out to the subject side and you can see a live view of what you are filming. Using the unique built-in stand you can tilt LEGRIA mini X up to a maximum of approximately 60°, giving you a range of perspectives for your movie and reducing the need for a tripod. Stow the stand away or pull it out as required.
