This compact and reliable A4 B&W laser printer boasts Adobe PostScript support for fast, high-quality results, plus a great choice of cloud and connectivity options for today's mobile devices.
Key Features
- Compact, reliable A4 B&W laser printer for small workgroups and businesses.
- Rapid, high quality 33 ppm printing helps keep your teams productive.
- Ideal for frequent print tasks like forms, invoices, receipts and delivery notes.
- Adobe PostScript support for easy network integration.
- Consistent reliability and quality via Canon All-in-One replacement cartridges.
- Free Canon app to work on the go with your Apple and Android devices.
- Protect confidential documents via PIN code even when printing remotely.
- Powerful connectivity including Apple AirPrintâ„¢ and Google Cloud Print.
- Energy saving features like Auto Shutdown help keep your business sustainable.
- Easy to monitor and update remotely via a web browser.
Get started with high quality workgroup printing
Small businesses and workgroup teams can easily achieve great results with this well equipped A4 B&W laser printer. The i-SENSYS LBP252dw's compact size and smart looks are ideal in customer-facing environments or busy offices. And you'll complete everyday tasks faster with rapid 33 ppm output and the ability to start printing from idle or standby in just a few seconds.
Sustained quality, easy ownership
Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon's easy-to-replace All-in-One cartridge design. Want your printer to run longer with fewer interventions? Choose the longer-lasting high yield cartridges. Even better, with just a single cartridge to keep track of, you'll have fewer items to order and manage, reducing your admin workload.
Great support for mobile and cloud
Do you and your teams enjoy the flexibility of moving seamlessly between locations and devices? Then the LBP252dw is ideal for you. No matter how or where you choose to work, your LBP252dw is always ready and accessible. Print from your iPhone or iPad via Apple AirPrint, or your Android device using Google Cloud Print, regardless of whether you're inside or outside the office.
Protecting your information and your bottom line
Concerned about document confidentiality in the office? Enjoy peace of mind using the Secure Print Function that enables you to securely print private and confidential documents using a PIN code. The LBP252dw protects your profitability too, with features like double-sided printing that reduce wasted paper, and Auto Shutdown that conserves electricity when your printer's not in use.
Network and integration-ready on-board Wi-Fi
The LBP252dw offers sophisticated capabilities for integrating seamlessly with IT networks. Support for PCL5e/6 and Adobe PostScript makes it an ideal choice for managed environments; while the Remote User Interface saves valuable time because IT Managers can monitor and update settings without making a site visit. And with Wi-Fi and Ethernet connectivity as standard, the LBP252dw has all the features you need to keep pace with your growing business.
