| Quicklinx: | FRZJWS00 |
| Mfr#: | 3513C013 |
Get print, scan, copy and fax functionality from one compact printer, perfect for businesses tight on space. With flexible connectivity, rapid printing and intuitive controls, the MF543x will take productivity to another level.
Canon i-SENSYS MF543x in More Detail
Offering print, scan, copy and fax functionality in a compact footprint, the Canon i-SENSYS MF543x is a fast and versatile mono multifunction laser printer that has been designed with hard-working businesses in mind. With fast printing speeds, flexible mobile connectivity and advanced customisable controls, it’s the perfect device for busy small businesses which are looking for a powerful space-saving solution.
Take productivity to another level
The Canon i-SENSYS MF543x is ready to take your team’s productivity to another level. It offers ultra-fast printing speeds of up to 43ppm for single-sided A4 and has a first page out time as fast as 5.7 seconds, meaning you’ll be able to print all your documents quickly and efficiently. In addition, double-sided printing and single-pass double-sided scanning work to further boost your productivity and make it easier to get through larger workloads.
Powerful controls
The large 12.7cm colour touchscreen offers intuitive on-screen controls and makes it easy to operate the functions of the device. Canon’s unique Application Library allows you to tailor on-screen options to suit your individual needs and provides convenient one-touch access to the functions you use every day, like scan to email or printing a saved form.
Versatile connectivity
The Canon i-SENSYS MF543x delivers simple mobile connectivity and offers a variety of versatile connection options, including USB, Network, Wireless and Wi-Fi Direct. There’s also support AirPrint and Mopria, allowing you to print wirelessly from iOS and Android devices with the tap of a button. Meanwhile, NFC pairing enables you to connect Bluetooth devices simply by touching them.
Performance and security
You can rely on the Canon i-SENSYS MF543x to produce high-quality prints time after time. It’s also ideal for handling sensitive documents, with a built-in PIN document release function that holds print jobs until the required PIN is entered into the machine.
