| Quicklinx: | FRZGWS00 |
| Mfr#: | 3514C032 |
The MF449x has it all - print, scan, copy and fax from one sleek machine and keep a tight rein on security and costs via the Universal Login Manager (ULM). Customizable controls make operation even more user-friendly.
A smart, connected B&W printer to give your business the professional edge
Get the most from your small office with this compact, multi-talented MF449x. Easy to control from a touch screen display, this smart printer can be networked, enabling your entire team to print, copy, scan and fax from any device. Plus, with cost and waste saving features you’ll protect the environment and your budget.
Take control of your print environment
Always be in control with an intuitive 5 inch Touch LCD Display loaded with details you need to operate, manage and maintain your printer.
Never miss a beat, even when you’re out and about
Don’t lose time. Print on the go from your smartphone or tablet using AirPrint, Mopria for Andriod and Canon’s Print Business app.
Built for connectivity
Boost productivity with your networked office integrating PCL5e/6 and Adobe PostScript printer languages thanks to WiFi and Ethernet connectivity.
Equipped for smart printing on the fly
Don’t hold back. With Google Cloud Print, Apple® AirPrint, Mopria (Android) and Canon’s PRINT Business app, you can print from any smart device.
Connected so you can share and collaborate
Connect, share and collaborate for best results with MF Scan Utility, Canon’s PRINT Business app and cloud storage like Evernote® and DropBox.
Compact yet impressive
Achieve professional results in black and white at high speeds from your robust compact printer that can fit into the smallest, busiest workspace.
Speedy from the get go
No waiting required. Your MF449X prints within 6 seconds then races at up to 38ppm at an impressive 600 x 600 dpi with capacity for 1200 x 600 dpi.
Protect your environment and your budget
Protect your environment with low energy consumption, a smart power-saving Auto Off feature and automatic duplex printing to reduce paper waste.
