Quicklinx: | CJMXWS00 |
Mfr#: | 0291C035 |
An ideal addition to your fleet of networked printers, the smart, simple and compact MF418x black and white Multifunctional printer offers laser-quality print, copy and scanning plus full support for flexible working.
Benefits
* Black and white A4 laser Multifunctional printer with WiFi that’s tailor-made for small workgroups
* Fast, professional-quality printing at up to 33ppm
* Easy operation using the intuitive colour touch screen
* Automatic duplex printing reduces waste and overheads
* Quick First-Print saves time and keeps your teams productive
* Secure PIN printing
* AirPrint, Mopria and the Canon PRINT Business app for printing from smartphones and tablets
* Works easily with popular cloud storage services
* Easy integration with device and output management capabilities
* Simple to maintain with convenient All-In-One Cartridges
Work smarter in the office-
Small workgroups can gain a welcome productivity boost from the MF418x A4 laser Multifunctional printer. Offering professional-quality printing speeds of up to 33ppm, the MF418x is versatile enough to handle all your document needs despite its impressively compact size. An intuitive 3.5" colour touch screen, 550-page paper capacity and Quick First-Print from start-up all help your teams to work more efficiently and without interruption. The MF418x also offers a convenient privacy feature a convenient privacy feature: the Secure Print function protects your documents with a PIN code, even when you’re printing from a mobile device.
Flexible working-
Thanks to the MF418x’s extensive support for Apple AirPrint (iOS) and Mopria (Android), your workgroup can print from any enabled device. They can also access a wide range of advanced features with the Canon PRINT Business app and can connect the device to a Google Cloud Print account in seconds.
Enhanced document sharing-
The cloud-ready MF418x can help your business to become more agile. Using the MF Scan Utility (for PCs/laptops) and the Canon PRINT Business app (for mobile devices), everyone can connect seamlessly between the MF418x and popular cloud storage services like Evernote® and DropBox to capture, digitise and share documents on the go – or simply to scan and email in a single operation.
Smart networking capabilities-
With a host of flexible networking capabilities, the MF418x makes a perfect addition to your network. WiFi and Ethernet connectivity, alongside support for PCL5e/6 and Adobe PostScript printer languages, enable hassle-free integration into managed network environments. With Canon’s e-Maintenance remote service management and support for Canon’s uniFLOW output management system make the MF418x equally well-suited to managed network environments.
Simple and sustainable ownership-
Consistent reliability and renewed quality are ensured every time you change your toner thanks to Canon’s All-In-One Cartridge design that replaces all key components at once with every toner change. And with low energy consumption in Sleep and Standby modes, automatic duplex printing, and a smart power-saving Auto Off feature, the MF418x makes a sustainable, cost-conscious choice.
