Canon i-SENSYS MF226dn is a powerful, network ready mono laser All-In-One for busy small offices. Boost productivity with fast automatic 2-sided printing and ADF. Set up efficient workflows with quick one-touch solution keys.
This compact and stylish mono laser All-In-One offers the convenience of a professional quality printer, scanner, copier and fax in one space saving device. Network ready its productivity boosting features can be shared seamlessly across your office – making it the ideal choice to increase the efficiency of any busy office.
Fast printing and copying
There’s no waiting for documents thanks to a fast A4 mono laser print and copy speed of 27ppm and a Quick First Print from sleep mode.
Business quality results
A combination of high print quality and Canon’s EF toner delivers impressive documents with sharp text and smooth grayscale graphics. Enhanced color scanning captures every detail from originals. Send scans to any PC with user-friendly network scanning.
Efficient 2-sided printing
Multi-page scanning and copying is quick and efficient thanks to an integrated 35-sheet ADF and a 250-sheet paper cassette. Save money on paper and print professional looking documents with automatic 2-sided printing.
Quick, simple, quiet operation
Quick and simple to operate, the i-SENSYS MF226dn has a versatile, tilting display panel with a large touch screen LCD, which shows you the information you need at a glance. The panel can be set vertically or placed facing upwards to suit the way you work. Efficient scanning and copying workflows are simple to set up using the quick one-touch solution keys, so it’s easy to send scans to file or save paper by copying several images to one sheet. For operation in a quiet environment, Quiet Mode ensures less noisy printing so you can work without distracting others.
Market leading energy efficiency
Canon’s On-Demand fixing technology ensures virtually no warm up time and helps cut energy consumption without affecting performance. With a class leading TEC rating, this device consumes just 1.7 Watts in sleep mode.
All-in-One cartridge
The recyclable All-in-One cartridge ensures maintenance-free operation and reliable high quality output. The Authentic Canon Laser Cartridge contains toner, drum and cleaning units and can be replaced in seconds without any fuss or mess.
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Input tray - 250 sheets size: 76.2 x 210 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets , ADF - 35 sheets size: 105 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 27 ppm (A4) - B/W , Copying: up to 27 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2
