The i-SENSYS LBP151dw is a fast, compact, PCL-ready, Wi-Fi and mobile-enabled black and white laser printer that's affordably priced and ideal for a wide range of uses.
The i-SENSYS LBP151dw delivers outstanding speed from a space-saving device, at a very affordable price point. A brisk print speed of 27 ppm is complemented by double-sided printing, a first page out time (FPOT) of 8 seconds and Canon's Quick First-Print technologies, to ensure speedy printouts, even from sleep mode.
Wi-Fi, network and mobile-ready
Connecting the printer to an Ethernet or Wi-Fi network is as easy as pushing a button. You can print wirelessly from any Mopria-enabled mobile device, using the free plugin. And you can access a wide range of advanced features on your iOS or Android device with the free-of-charge Canon PRINT Business app.
Google cloud print-ready
The i-SENSYS LBP151dw will connect directly to the cloud without a PC. You can connect it to your Google Cloud Print account in seconds, and immediately start printing to it from any enabled device.
PCL-ready
For IT professionals, the i-SENSYS LBP151dw is the perfect solution to numerous problems, attaching seamlessly to the network and providing compact, inexpensive reliability.
Efficient, low power consumption
This printer is both quiet, making it ideal for retail environments, bank branches and hotel receptions and has class-leading energy efficient with low power consumption.
Canon i-SENSYS LBP151dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
8.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
400 MHz
RAM Installed (Max)
512 MB
Language Simulation
PCL 5E, PCL 6, Canon Ultra Fast Rendering (UFRII)
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet paper cassette, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
500 - 2000 pages
Print server
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
39 cm x 36.5 cm x 24.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
45 x PCL
Media Handling
400 MHz
RAM
RAM Installed (Max)
512 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
15000 pages
500 - 2000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1700 pages - Canon 737 Starter
ISO/IEC 19752, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
1120 Watt
Power Consumption Stand by
2.6 Watt
Power Consumption Sleep
1.1 Watt
Software Included
Drivers & Utilities, Canon Print Service plug-in for Android, Canon PRINT Business
