Quicklinx: | 8CJ9WS00 |
Mfr#: | 6559B024AA |
Canon EOS 650D - High-quality, entry-level EOS. First choice for those starting their DSLR adventures.
An ideal entry to the world of EOS imaging. The EOS 650D's 18.0-megapixel sensor is superb for both still images and Full HD movies. A Vari-angle Clear View LCD II Touch screen makes shooting simple.
- 18.0 MP APS-C CMOS sensor
- Full-HD movies with manual controls and continuous AF
- 5 fps continuous shooting
- Vari-angle Clear View LCD II Touch screen
- ISO 100-12,800 sensitivity, extendable to ISO 25,600
- 9-point wide-area AF
- Integrated Speedlite Transmitter
Advanced image quality
Capture every detail with 18-megapixel resolution, and enjoy the smooth tones and accurate colours of 14-bit DIGIC 5 image processing. The EOS 650D produces files big enough to print at large sizes or crop for alternative compositions without sacrificing quality.
Produce Full HD movie projects
Capture premium-quality movies at 1080p resolution, enjoying the right level of automatic or manual control for you. Autofocus is possible while filming, and a built in microphone enables the recording of high-quality stereo audio.
Keep up with fast moving action
Track moving objects accurately across the frame with an autofocus system comprising nine cross-type AF points. Continuous shooting at 5 fps for bursts of up to 22 frames means you'll never miss that decisive moment.
Explore new viewpoints
The EOS 650D has a Vari-angle 7.7cm (3.0") 3:2 ratio Clear View LCD II Touch screen that hinges away from the camera's body and rotates through 270º. This enables video and still-image shooting from alternative viewpoints - such as over the top of crowds or from waist level.
Touch-screen control
Enjoy alternative access to the EOS 650D's controls through a Vari-angle Clear View LCD II Touch screen. Shoot and focus with a single tap and use pinch and swipe gestures when reviewing images.
Low-light performance
The EOS 650D can capture images over a sensitivity range of ISO 100-12,800 (extendable to ISO 25,600), enabling hand-held shooting in low light without using flash.
Explore creative lighting options by positioning Canon Speedlite flashes off camera and controlling them with the EOS 650D's Integrated Speedlite Transmitter.
Scene Intelligent Auto
Canon's Scene Intelligent Auto technology analyses each scene and sets the most appropriate combination of cameras settings automatically.
Great results in difficult conditions
HDR Backlight control captures three different exposures and combines them into one, retaining shadow and highlight detail. The EOS 650D's hand-held night scene mode captures multiple images at fast shutter speeds and blends them together for a blur-free result.
