Please Note: EOS 200D with 18-55mm lens shown for illustration purposes. 18-135mm lens supplied.
Affordable, easy to use, and delivers great results. This EOS 200D kit also includes an EF-S 18-135mm f/3.5-5.6 IS STM lens that's ideal for travel, landscapes and everyday photography
The world's lightest DSLR¹ with a Vari-angle screen - the EOS 200D is a great choice for landscapes, portraits and travel and captures great quality photos and movies with a next-generation 24.2-megapixel sensor. It's connected too, designed to work with smartphones and tablet computers². The included EF-S 18-135mm f/3.5-5.6 IS STM lens provides smooth quiet auto focusing for movies, and Dynamic Image Stabilizer reduces vibrations in video footage.
Benefits
- An ultra-compact DSLR that's easy to use and delivers superb results
- A great camera for landscapes, portraits and travel. Capture intricate detail with a 24.2-megapixel sensor
- The included EF-S 18-135mm f/3.5-5.6 IS STM lens is suitable for many different types of photography, from landscape to portrait
- Images are sharp and clear, thanks to autofocus that's accurate even in dim light
- STM focusing is fast when shooting photos and smoother for video
- Enjoy a responsive performance, whether you're composing with Live View or using the high-quality optical viewfinder³
- Low Energy Bluetooth® maintains a connection with your smart device without excessive battery drain
- Share images from your smart device and control your camera remotely, using Bluetooth® and Wi-Fi²
- Shoot superb Full HD video that looks amazing online and on your home TV
- Part of the EOS family: a system of lenses and accessories that empowers you to be creative
What's in the box
- EOS 200D Black
- EF-S 18-135mm f/3.5-5.6 IS STM lens Black
- Eyecup EF
- Camera Cover R-F-3
- Wide Strap EW-400D
- Battery Charger LP-E17 (with battery cover)
- Battery Pack LP-E17E Power Cable
