Step up to DSLR image quality with a 12-megapixel APS-C-sized sensor. A 14-bit DIGIC 4 image processor provides 3.2fps continuous shooting and images that are packed with detail and tonal range.
Intuitive, on-screen feature guide
The EOS 1100D's feature guide provides descriptions of many of the camera's functions, as well as advice on how to use them in your own photography.
Easy to use Scene modes and Basic+
Theme-based Scene modes automatically pick the most suitable exposure, focus and drive-mode settings for the subject being photographed, while Creative Auto mode portrays adjustable functions in an easy to understand way. With Canon's Basic + technology, the look and feel of these basic auto modes can be fine-tuned according to ambience and lighting type.
HD EOS movie mode
Shoot stunning HD video at 25 or 30 fps, with automatic exposure control leaving you free to concentrate on the action. Footage can be edited on your PC or Mac, or played directly on an HD TV via the camera's HDMI connection.
ISO 100-6400 sensitivity
Low-light shooting without flash is possible thanks to the EOS 1100D's ISO 100-6400 sensitivity range. The camera's 14-bit DIGIC 4 processor helps to control noise and maintain image quality.
Wide-area 9-point AF system
The EOS 1100D focuses quickly and accurately on static and moving subjects, thanks to nine AF points, spread out across the frame. A central cross-type AF point is sensitive to both horizontal and vertical lines.
63-zone iFCL exposure metering
Advanced iFCL exposure metering dissects a scene into 63-zones before analyzing it to find the perfect combination of shutter speed, aperture and ISO.
6.8 cm, 230,000-dot LCD screen
Compose and review images on a large 230,000-dot LCD screen, which also provides access to the camera's menu system and Quick Control Screen.
Canon EOS 1100D - digital camera - body only
Digital camera - 720p - SLR with Live View mode, movie recording
Lens Included
Body only
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensor Resolution
12.0 Megapixel
Max Video Resolution
1280 x 720
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level mirror pentaprism
Display
LCD display - 2.7"
Supported Battery
Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
13 cm x 7.8 cm x 10 cm
495 g
Lens Included
Body only
Enclosure Colour
Sensor Resolution
12.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
12,600,000 pixels
Effective Sensor Resolution
12,000,000 pixels
Optical Sensor Size
APS-C (22.2 x 14.7 mm)
Field of View Crop Factor
1.6
ISO (Max)
6400
Image Processor
DIGIC 4
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
2 frames per second, 3 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, digital noise reduction, depth-of-field preview button, histogram display, AE lock, AF lock, FE lock, highlight tone priority, LCD live view mode, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.8x
Optical Viewfinder Dioptric Correction Range
-2.5 to +0.5
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status
Display
2.7" LCD display
Display Format
230,400 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output , HDMI output , Remote control
Battery charger, body cap, neck strap, USB cable, eyecup, audio / video cable
