Canon EF-S 18-55mm f/3.5-5.6 IS STM
The ideal standard lens for those starting out in DSLR photo and video
An affordable standard zoom lens suited to a variety of subjects. Enjoy smooth, near-silent focusing when shooting video, with STM motor technology and Movie Servo AF. A four-stop Image Stabilizer reduces camera shake.
- Versatile zoom range - great for landscapes, portraits and travel
- Compact lightweight design
- Avoid camera shake with a four-stop optical Image Stabilizer
- STM Motor gives smooth, near-silent focusing when shooting video
- 0.25m close focusing distance
An ideal first step into the DSLR world
Tackle a range of subjects, from landscapes to portraits and action, with a versatile 18-55mm zoom range. Lightweight construction makes this a great everyday lens.
Increased sharpness with four-stop Image Stabilizer
An optical Image Stabilizer reduces the risk of camera shake, enabling hand-held photography in low-light conditions without flash. Use shutter speeds up to four stops longer than normal without blur from camera movement.
Quiet, smooth focusing in movies
STM Motor technology provides near-silent focusing to leave your video soundtrack uninterrupted by noise, and adjusts smoothly and precisely as you shoot.
Designed for great photography
Focus on small subjects, with a closest focusing distance of just 0.25m. A non-rotating front element makes using filters straightforward, and a manual focus ring enables manual override of focusing at any time.
Great image quality, whatever the subject
A Super Spectra Coating is used to reduce flare and improve sharpness, while a seven-bladed aperture provides smooth out-of-focus highlights for a more natural look and feel.
