Canon EF-S 18-135mm f/3.5-5.6 IS
The versatile, all-purpose powerful standard zoom lens.
Offering a multi purpose zoom range from wide angle to telephoto, and featuring Canon's 4-stop Image Stabilizer, the EF-S 18-135mm f/3.5-5.6 IS provides complete versatility what ever your needs.
- High power, all-purpose 7.5x, 29-216mm equivalent, EF-S zoom
- 4 stop Image Stabilizer
- Automatic panning and tripod detection
- 0.45m close focusing
- UD and aspherical lenses
- Super Spectra coatings
- 6-blade circular aperture
- Optional lens hood
The multi function zoom lens
Offering a 35mm equivalent effective focal length range of 29-216mm, the EF-S 18-135mm f/3.5-5.6 IS combines the majority of all the most popular focal lengths in one lens. Whether it's a wide angle for landscapes you need, or a telephoto for sports day, the EF-S 18-135mm f/3.5-5.6 IS covers all your requirements.
Image Stabilizer
The EF-S 18-135mm f/3.5-5.6 IS features Canon's 4-stop Image Stabilizer (IS). Ideal for low light conditions when a tripod can't be used, the Image Stabilizer system allows shutter speeds of up to 4 stops slower than normal to be used without causing image blur.
Beauty is not just skin deep
The EF-S 18-135mm f/3.5-5.6 IS also features a textured exterior finish for a sophisticated look and feel that matches your EOS camera.
High speed auto focus
A new DC autofocus motor combined with a high-speed CPU and improved AF algorithm enables quick and accurate auto focus performance.
Canon's Super Spectra lens coating is used to prevent flare and ghosting, which are more prone to occur with digital cameras due to reflection off the image sensor. The use of optimised lens coatings prevent flare and ghosting and ensure excellent color balance and contrast.
Discover creative blur
A 6-blade circular aperture enables you to blur your background creatively. This can be used to enhance portraits by creatively blurring background detail making the subject more striking.
