Canon EF 50mm f/1.4 USM
The ultimate mixture of versatility and image quality.
With its fast maximum aperture and rapid focusing system, the compact, high performance EF 50mm f/1.4 USM standard lens can be relied on for superb performance in any field of photography.
- Fast f/1.4 aperture
- Standard 46° angle of view
- USM focus motor with full-time manual focus override
- 45cm closest focusing distance
- Aspherical lens element
- 58mm filter size
Versatile, compact standard-lens design
Gaussian optics, combined with two high-refraction lens elements allow photographers working in all fields to capture crisp, clean images, even wide open at f/1.4. The lens is ideal for photographing landscapes and travel scenes as well as portraits and reportage.
Ultrasonic focusing
A ultrasonic motor drives autofocus extremely quickly, and in near silence. Excellent holding torque ensures the point of focus is reached accurately, without overshooting. Furthermore, full-time manual override is available, making it possible to adjust focus without leaving AF mode.
Smooth background blur
A virtually circular aperture diaphragm gives out of focus regions a softer, more uniform feel. Sharp foreground objects stand out against a smooth blurred background.
Super Spectra coating
Super Spectra coatings ensure accurate colour balance and enhance contrast. They also reduce flare and ghosting - a common problem caused by light bouncing off a camera's sensor.
