A high-performance wide-angle lens, the EF 24mm f/1.4L II USM's fast f/1.4 aperture and combination of UD and aspherical lens elements delivers outstanding, professional image quality.
The EF 24mm f/1.4L II USM has a large maximum aperture of f/1.4, offering the chance to capture superb low-light photographs, as well as a circular aperture and narrow depth of field to give pleasing background blur. A focal length of 24mm is ideal for wide-angle photography: making the lens well-suited to the needs of photojournalists, landscape photographers and those who enjoy taking images from a wider perspective.
Aspheric and UD elements
Image quality has been greatly improved with the EF 24mm f/1.4L II USM thanks to the addition of two high-precision aspheric lenses to correct aberration including curvature of field and distortion. Chromatic aberration common in wide-angle shooting is also combated by the inclusion of two UD lenses, ensuring optimum image quality and corner-to-corner detail.
Subwavelength structure lens coating
Designed for use in digital photography, Canon's patented lens element coating helps minimize the ghosting and flare caused by internal reflections. By eliminating the cause, the coating reduces reflections and helps to deliver crisp, clear images.
USM focus motor
The EF 24mm f/1.4L II USM's near-silent Ultra Sonic Motor (USM) provides super-fast auto-focusing with full-time manual override. The floating internal focus system also helps maintain high image quality throughout the focal range.
Robust build quality
Canon lenses are built to withstand regular use in the most testing environments. Weather and dust seals provide added protection, and a lens hood and pouch are also included in the package.
Lead-free optics
Environmentally friendly lead-free glass is used throughout the construction of the EF 24mm f/1.4L II USM.
Canon EF wide-angle lens - 24 mm
Lens System
Wide-angle lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF
Lens Aperture
F/1.4
Focal Length
24 mm
Min Focus Distance
25 cm
Focus Adjustment
Automatic, manual
Lens Construction
10 groups / 13 elements
Special Functions
Wide angle
Filter Size
77 mm
Length
8.7 cm
0.65 kg
EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
8.7 cm
Diameter
9.4 cm
0.65 kg
Lens System
Wide-angle lens
Special Functions
Wide angle
Intended For
Focal Length
24 mm
Lens Aperture
F/1.4
Minimum Aperture
F/22
Magnification
0.17
Min Focus Distance
25 cm
Focus Adjustment
Automatic, manual
Max View Angle
84 degree(s)
Lens Construction
Filter Size
77 mm
Diaphragm Blades
8
Lens Coating
Subwavelength Structure Coating (SWC)
Mounting Type
Canon EF
UD glass, internal focusing system, Ultrasonic Motor (USM), full-time manual focusing, floating system, aspherical lens, dustproof, weatherproof
Lens hood, dust cap, lens cap, carrying pouch
Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
