The LEGRIA HF R26 is an ideal companion if you're new to Full HD video. Features a Canon Full HD CMOS sensor, 28x advanced zoom, touch-screen and intelligent smart auto for superb results every time.
The Full HD 3.2MP CMOS sensor gives true HD quality and excellent color reproduction even in low light, so your movies will look great on your HDTV. Capture high-resolution 3.0MP still photos at the touch of a button.
Fingertip control
Operation is easy with a high-resolution 7.5cm (3.0") gesture-based touch-screen LCD, which gives you intuitive fingertip control of settings and simplifies playback.
28x advanced zoom
A genuine Canon HD video lens with 28x advanced zoom lets you get close to even far away subjects.
8GB dual Flash memory
A 8GB dual Flash memory lets you store over 3 hours of movies to the built-in memory. Record even longer with two SDXC card slots or upload wirelessly with an Eye-Fi card. Relay recording automatically switches cards if one becomes full. Copy between memory cards and convert movies from HD to SD in camera for really easy sharing and web uploading.
Smart auto with tele-macro
Effortlessly shoot high quality video with smart auto. Intelligent Scene Detection technology selects the perfect settings from 38 scene modes - all you have to do is point and shoot. Shoot extreme close ups with auto tele-macro mode.
Dynamic image stabilizer
Canon's dynamic electronic image stabilizer ensures all your movies have a smooth professional look even when shooting while walking. Easily switch between dynamic and standard mode.
Fun touch decoration
Add fun effects to your movies without a PC using touch decoration. Write messages straight on the touch-screen with the stylus pen, add stamps or active animations like shooting stars and mix in still images.
Top-quality action videos
The LEGRIA HF R26 records Full HD quality at a fast maximum bit rate of 24Mbps so you're sure of top-quality footage of fast moving subjects - perfect for action videos.
Fun, short movies
With video snapshot it's easy to create fun movies to share with friends - without a PC. Capture 2, 4 or 8 second clips with just one touch of the record button, create a playlist, add music and your movie is ready.
Precise focusing
Face detection automatically optimizes settings for perfectly focused people shots.
