High Capacity toner options keep up with your busy printing needs, so you have less replacement efforts and more time.
The 055 H Cyan Toner Cartridge is designed to maximise the potential and print quality of compatible i-SENSYS laser printers. This cartridge has a high yield of 5,900 pages and is ideal for very busy offices with a demanding workload, holding more than twice the standard 055 cartridge. The all-in-one design and easy installation allow any member of staff to fit a new cartridge when it’s needed and the cartridge itself is fully RoHS compliant and the packaging is fully recyclable.
