The VGA to HDMI converter can convert the analogue signal coming from your PC into a digital HDMI signal. This allows you to plug your older laptop or desktop computer into a modern HD television.
You can not only enjoy a high definition image but also audio from the 3.5mm stereo socket. Power is provided from the included USB cable; simply plug this into your computer. No external power adapter is needed.
- Easy to Use: Installs in seconds, does not need drivers
- Conversion: It can convert VGA & Audio into a complete HDMI signal
- Leaded type adapter with built-in VGA & Audio cable
- Input: VGA Signal, 3.5mm stereo and USB power
- Output: HDMI Signal
