Make your work environment more flexible and efficient. This heavy duty 1.5mm² cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
