Conquer USB length limitations and put your USB devices where you want them with the Super Booster USB Extender from C2G. This plug-and-play device consists of a base unit and a remote unit connected together by a standard Cat5, Cat5E, or Cat6 network cable. Simply connect your cables to your device; then connect to your computer and USB peripheral and you're up and running.
