This HDMI Micro to VGA and Stereo Audio Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Micro-enabled Chromebook, laptop or other source device to a VGA display and set of speakers for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA and stereo audio cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
