The HDBaseT HDMI + USB over cat5 extender is the perfect solution for long distance delivery of audio, video and USB signals from a computer or media player to an interactive whiteboard, touch screen, digital signage or other interactive display requiring high quality ULTRA HD video resolutions of up to 4K at 60Hz (2160p) at distances of up to 100 metres (328 feet). This HDBaseT HDMI + USB over Cat5 extender functions as an interface point for remote terminals, which provides a straightforward solution to control remote devices. With 4K HDMI AV output and four USB ports, this kit allows for multiple USB devices such as a touch screen, conference camera, mouse or keyboard next to an HDMI display to be installed in a remote location. With no drivers or software to install, the HDMI + USB over Cat5 Extender provides total plug and play convenience, passes EDID and HDCP and supports all USB 2.0 functionality. Simply run two solid Cat5e or Cat6 cables up to 100 metres (328 feet) between the transmitter at the source and the receiver at the display, connect all applicable devices, connect the power adapter and turn power on for all devices. The extender also extends IR and Serial control up to 100 metres using a standard remote.
