Use existing serial or modem cables and serial adapters from C2G to convert existing DB9 ports to DB25 or vice versa. Serial adapters are an inexpensive alternative to buying cables. With their molded design providing a solid connection, each adapter is shielded against outside EMI/RFI interference while giving you the flexibility to meet your connectivity needs.
