The VGA to HDMI converter is the ideal solution for attaching a PC to newer monitors or TVs that do not have an HD15 (VGA) input. With an added 3.5mm audio connection, enjoy high definition video and audio. The converter is simple to use with no software or drivers required. Simply connect the converter and begin enjoying PC content on your display. This is the ideal solution for viewing PC content on HDMI-enabled monitors.
Note: This converter does not have an upscaler. All signals are not converted to 1080p. Input signals will be converted to similar resolution on HDMI output.
Pack Contents
- VGA to HDMI Converter
- 100-240V AC, 50-60 Hz, 5V DC, 1000 mA power adapter
- User manual
Input Resolutions Supported:
- 640 x 480 pixels
- 720 x 576 pixels
- 800 x 600 pixels
- 1024 x 768 pixels
- 1280 x 720 pixels
- 1280 x 768 pixels
- 1280 x 960 pixels
- 1280 x 1024 pixels
- 1360 x 765 pixels
1920 x 1080 pixels
Weight : 0.508 KG
- Color : Black
