Make your work environment more flexible and efficient. This heavy-duty 14 AWG cord works with monitors, scanners, printers, and other devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully molded design for maximum durability and long life.
The female connector plugs directly into the device while the male connector plugs into another power cord or auxiliary power port on power supply for auto power when the system is turned on.
