Ground loop isolation transformers from C2G connect easily into your A/V system and break the ground path through cables between components. Start at the component last installed before the ground loop was discovered and connect the isolation transformer at different ends of the A/V cable until the ground loop is gone. They offer ground loop isolation transformers for composite video, S-video and component video applications.
