The 3.5mm stereo audio cable is specifically designed for quality computer audio applications. It attaches a PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with a braided shield which prevents unwanted EMI/RFI interference. Fully moulded nickel-plated connectors provide excellent strain relief for durable use.
Product Specifications
- Color: Black
- UPC: 757120801207
- Warranty: Lifetime
- Weight: 0.106 KG
- Length: 7.00 Meter
- Volume: 195.0 CCM
- Connectors: 3.5mm Stereo Male to 3.5mm Stereo MaleFoil shielded
- Nickel-plated connectors
