Easily add 4 additional USB 3.0 ports for SuperSpeed USB 3.0
The USB 3.0 4-Port Hub is compliant with USB 3.0 specification while also being backward compatible with the USB 2.0 specification. The USB SuperSpeed Hub allows for easy connection of up to 4 USB 3.0 devices to your computer, such as an MP3 players, digital cameras, or hard drives. The streamlined, sleek and compact design is the perfect solution for USB port expansion. The removable aluminum base can be hard-mounted to your desk. The hub easily slides from the base, and makes it convenient for travel as well.
- Each USB 3.0 port transmits 480Mbps/5Gbps per the USB 2.0/3.0 specification
- Fully compatible with USB 3.0 specification, and backward compatible with USB 2.0
- Supports up to 127 devices
- Self-powered with optional power supply for full powered device needs
- Automatic self-power status monitoring
- Plug and Play functionality
- 1 upstream and 4 downstream USB 3.0 ports
- CE and FCC approved
- Operating System: Windows XP, Vistaâ„¢, or 7
- Desktop or laptop with at least one USB 3.0 port (or a USB 2.0 port for 2.0 speeds)
- Weight : 0.618 KG
- Color : Black
Package Contents
- USB 3.0 4-port Hub
- Power Adapter - 5V 4A
- 6ft USB 3.0 Cable
- Hard-mountable base and screws
- User Manual
