Bring ultimate flexibility to your video connections with the patent-pending VGA270+3.5mm UXGA monitor plus audio cable. The 270° HD15 connectors on each end rotate side-to-side in almost a complete circle, allowing you to position the cable to fit your installation. The connectors feature detents, or click-stops, every 90° to ensure signal integrity is maintained. The 3.5mm audio cables are right angled to assist in creating a clean looking installation.
The oversized thumbscrews are slotted for easy connection to your equipment. Constructed from three coax and four twisted pair with an overall foil and braid shield, this UXGA cable supports the highest resolution video signal. With its premium quality and incredible versatility, this UXGA cable is ideal for connecting video equipment including projectors, video splitters, monitors, and KVMs. With VGA270+3.5mm audio, the days of not having the right connector orientation on your cables are over!
