Use this DisplayPort to DVI cable to connect a DisplayPort source directly to a DVI monitor or display. The passive design will support a 1920 x 1080 resolution up to 3 metres. It is VESA-compliant with transparent operation which will auto-calibrate and configure the signal for minimal configuration. Great for applications when you want to connect a newer laptop or desktop to a DVI-enabled display.
