Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
