Buffalo's new AirStation Dual Band 11ac Wireless Gigabit router (WZR-1750DHP-EU) brings a new and versatile dual band solution with blazing fast transfer speeds and beamforming technology. The WZR-1750DHP-EU is primed and ready-to-go with transfer speeds of up to 1.3GBps in the 5GHz spectrum and 450Mbps on the 2.4GHz bandwidth! The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new AirStation's simultaneous fast transfer speeds in the 2.4GHz bandwidth.
Buffalo's new AirStation uses beamforming and Multi-user MIMO technologies to remarkably improve your wireless connection. MU-MIMO harnesses the WZR-1750DHP's antennas and beamforming recognizes the devices using wireless and focuses the signal directly to them. And once focused, your wireless signal will have better ability to reach around corners and through walls, helping to eliminate or reduce previous performance obstacles.
In addition to all of this, the AirStation Dual Band 11ac Wireless Gigabit router also offers Norton ConnectSafe web filtering and parental control by Symantec. Upgrade your existing wireless connection to provide greater coverage, beamforming, blazing fast transfer speeds - all whilst protecting your network and your family, Buffalo's (WZR-1750DHP-EU) is the next generation of wireless connectivity.
