The new Buffalo AirStation Wireless Router (WHR-1166D-EU) is ready for the latest 11ac smartphones, tablets, or laptops and designed especially for users focused on their wireless connections.
The WHR-1166D provides up to 866 Mbps transfer speed in the 5GHz band and simultaneous transfer speeds of up to 300 Mbps in the 2.4GHz band. Furthermore, easy setup is a few clicks away via a simple User Interface that's accessible on a computer, smartphone, or tablet. Buffalo's new AirStation is also very family-friendly with Norton ConnectSafe web filtering as well as Parental Control that allows you to limit the amount of time specific users are connected.
And for more advanced users the WHR-1166D also has functionalities like QoS, port forwarding and guest port. The guest port feature allows you to both share your internet connection with visitors and also isolate your own network devices - keeping you, and your guests, entirely separate. Buffalo's new AirStation can also be integrated into an existing network as a wireless range extender for even better and further reach.
Dual band 11ac with great wireless performance and security, Buffalo's new AirStation WHR-1166D-EU is a smart choice for homes and small office networks looking to upgrade their network with a fast 11ac wireless router.
LAN Ports - 4x100mbps RJ45 Auto MDIX
WAN Ports - 1x Gigabit RJ45 Auto MDIX
