Compact and Versatile Dual-Band Wireless Networking
Buffalo Technology's new Airstation™ Wireless N300 Dual Band USB Adapter (WI-U2-300D-EU) is a quick and easy way to make your computer compatible with new dual band high speed routers.
Users will be impressed by the speed and ease of the new Airstation™ adapter which is compatible with both the 2.4GHz and 5GHz bandwidths for maximum versatility.
The 5GHz bandwidth is much less crowded and therefore ideal for faster, uninterrupted HD video streaming and concurrent Internet access. And depending on your network conditions, there are also advantages, to utilising the 2.4GHz spectrum such as further range.
Be impressed by the speed and ease of the new Airstation™ adapter which is compatible with both the 2.4GHz and 5GHz bandwidths for maximum versatility. The 5GHz bandwidth is much less crowded and therefore ideal for faster, uninterrupted HD video streaming and concurrent Internet access.
High-speed streaming
Buffalo's new adapter makes fast data transfers, demanding applications, gaming, streaming video, and anything else, available in every corner of your home or office on almost any computer with an available USB port.
Easy, secure setup
Push-button wireless setup with the Buffalo AirStation™ One-Touch Secure System (AOSS™) and Wi-Fi Protected Setup (WPS)
Upgrade non-dual band computers
Fast and stable connections, a compact design that doesn't get in way, plus a clipping extension cable for optimal placement: Buffalo's new adapter is the easy way to upgrade non-dual band computers!
