Buffalo's 450Mbps Wireless-N Router supports 450Mbps speeds on the 2.4GHz band.
This router's Wireless performance redefines Wireless networking with higher data throughput and range. High Power technology provides even better coverage and signal quality in houses and large apartments. It easily streams HD video through the home and still lets you surf in the internet.
The patented AOSS technology allows you to establish secure connections by pressing 2 buttons. Alternatively it is possible to use Wi-Fi Protected Setup (WPS) to connect to other WPS supported Wireless adapters.
The WZR-HP-G450H is the ideal router for sharing your Internet connection and network resources; viewing files, listening to music, or watching videos.
Simple push button set-up for a great combination of speed and security! Advanced Multiple Input Multiple Output (MIMO) antenna technology improves the connection quality to each Wireless client.
Quality of Service (QoS) technology prioritizes gaming, Internet calls and video streams.
The WZR-HP-G450H is loaded with features, such as VPN via PPTP or OpenSSH, port and port range forwarding. The NFINITI HighPower Giga Wireless-N Router & Access Point is great for managing networks or for upgrading a network with an access point.
Easy setup in minutes
AOSS for secure Wireless connections by pressing two buttons
3 x 3 antennas provide 450Mbps
High Power technology to deliver faster throughput and better coverage
Pre-installed DD-WRT firmware for BUFFALOTM
USB port for NAS and Printer capabilities
VPN allows you to securely access a network from anywhere
Parental Controls
4 Port Gigabit switch
Wireless
2.4GHz band
IEEE802.11n standard, backwards compatible
3x3 TX/RX antennas
Supports 450Mbps data transfer in HT40 mode
1-13 channels for communication
Auto channel selector for using non-crowded channels
Repeater function to extend a Wireless network
Security
Support for WPS and AOSS
Mac address filter
Multi encryption levels for using WEP, TKIP and AES in the same Wireless network
Privacy separator prohibits unauthorised communication
USB Port
Supports USB 2.0 Host specification
NAS function is supported when USB mass storage device (HDD or USB flash) is connected
File sharing function, loading torrents, when USB mass storage device is attached
Other
VDSL Support without limit, good for upcoming 100MBit Lines
VLAN Tagging for WAN side access named as "T-Home VDSL" setting
Place it vertically, horizontally or mount in on the wall
