Buffalo's DriveStation USB 2.0 Hard Drive lets you store, backup, or easily transport various files, including huge multimedia files too large to fit on a USB key. Just plug it into your computer and it installs automatically with Windows 2000, XP, or OS-X computers. Fanless Heat Sink Chassis design lets the DriveStation run cool and quietly. The unique chassis design may be placed vertically or horizontally. With auto installation and SecureLockWare support, the DriveStation is a plug and play secure and reliable USB backup and storage solution.
Key Specifications
- USB 2.0 Interface
- Pre-formatted drive for immediate use
- Easy set-up, no drivers required
- Connects to USB on any PC or Mac
- Connector Type: USB Type B
- Data Transfer Rate Max: 480Mbps (USB 2.0 Mode)
- Setup Utility OS Support: Windows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
- Dimensions (W x H x D) 38.7 X 122.6 X 189mm
- Weight 950g
- Operating Environment 5-35°C, 20-80% (non-condensing)
