Storage solution that fits snugly into your palm: Buffalo LinkStation™ Mini is the perfect network storage for users on the go.
The first Network Attached Storage product in the world using 2.5" hard disks! The Auto Power on / off function enables the LinkStation to turn off automatically when you shut down the last PC or laptop with installed NAS Navigator software. So small and compact that it fits perfectly in the palm of your hand, with features such as 60% lower power consumption, fanless operation and low noise make the LinkStation Mini the ideal storage solution for anywhere in your home.
- Stream digital content to any DLNA™ media player: The built-in DNLA™ Media Server allows you to stream any audio and visual content to a TV or DLNA™ media player.
- Easy setup: The LinkStation™ Mini is easy to install. No drivers needed.
- Get quick access to your files anywhere: Access your files, music, photos and videos anywhere anytime through a Web browser using Buffalo's unique Web Access technology. Web Access lets you use your PC, Mac or iPhone to access and share digital content stored in your LinkStation™ Mini with anyone on your network.
- Save power, save the planet: The Auto Power on/ off function enables the LinkStation™ Mini to turn off automatically when you shut down the last PC or laptop on your network with the installed NAS Navigator software.
- Download your iTunes® playlists anytime: Seamlessly integrates with iTunes® so you can easily access your music files stored on the LinkStation™ Mini from your iTunes anytime.
- Powerful backup with NovaBACKUP® Professional: The LinkStation™ Mini is bundled with five licenses of NovaBACKUP® Professional. The NovaBACKUP® Professional automatically backs up your personal documents along with your favorite photos, music and videos, and protects your data on workstations locally and online. Regardless of theft, user error or hardware failure, NovaBACKUP® keeps your data secure.
- Active Directory support: Works as a client in an Active Directory domain allowing the LinkStation™ Mini to utilise the domain users and groups.
- Direct transfer of multimedia files: Direct Copy feature enables automatic upload of multimedia files from your digital camera or digital camcorder directly to your LinkStation™ Mini.
- RAID support: Three operating modes: RAID level 0, 1, JBOD - for greater flexibility
- UPS connectivity: Supports UPS (Uninterruptible Power Supply) connectivity via USB port.
- Built-in print server: Share a USB 2.0 printer on your home or LAN network via a built-in print server.
- Dedicated scripts and servers: LinkStation™ Mini runs on these scripts and servers: Apache Web server (full featured enhancement modules included); PHP5 Scripting language (fully supported by the Web server); MySQL database with phpmyadmin interface.
- Enhanced file transfer rates of up to 40mb per second: High-speed processor provides faster file transfer rates of up to 40MB per second.
- Gigabit Ethernet port: Auto sensing 10/100/1000 Gigabit Ethernet port for high-speed network connections.
- Restricted network access: Set access to network at group and user security levels to protect data.
- USB port: Expand storage by adding a USB 2.0 hard drive via the USB port.
- Supports Apple® Bonjour®
