BT 6500
Fed up with sales calls interrupting you at home? The new BT6500 brings you unique functionality to block nuisance or unwanted calls. It's call management feature puts you back in control, by enabling you to choose the calls you want to take and those you want to block.
(You must subscribe to a Caller
Display service from your
network provider for the block
nuisance calls feature to work.
Charges may apply.)
Block Nuisance Calls
With the BT 6500 you can choose the type of calls you want to block. For example International and Withheld numbers can be blocked, which account for a large proportion of unwanted sales calls. Calls still go through to the answer machine, so if it's someone you want to hear from they can still leave a message. Alternatively if you there are specific numbers you want to block, you can block up to 10 numbers from getting through.
Full of features that are simple to use
-Do Not Disturb For those times when you just want some peace and quiet, switch Do Not Disturb so that your phone won't ring or light up. If you want key friends and family to still get through they can do, by tagging them as VIPs in your address book
-Visual Voicemail - See a list of who's called you, and choose which message to listen to first
-Parental Control - prevent any surprises on your bill by PIN protecting calls to Mobile, International, Premium Rate numbers, or even ALL outgoing calls. This can also be useful for elderly customers or those with elderly relatives who may have a habit of racking up big bills unknowingly
-Call waiting - shows you who's trying to get through and at the press of a button you can switch to the new call or reject it
We've also made it easy to divert calls to your mobile or other numbers for when you're away from home. Or if you want to have a 3 way call the BT 6500 helps you get it set up in a few simple steps.
-All your numbers at your fingertips - With the BT 6500 you can save up to 200 contacts, letting you keep track of all your favourite people. All these contact are automatically copied to all of your handsets, ensuring you always have the numbers you need, and saving you time entering them more than once.
-Quality built-in - Great design, with a Large 1.8" Full-graphic display, that is easy to read. See instantly how many Voice messages, missed calls or text messages you have. Large enough screen for text messaging.
Specifically designed to give a clearer sound meaning you won't miss a word. Designed and stringently tested in the UK to ensure all phones meet our high standards.
The buttons have been thoroughly tested to ensure the 1000th press is the same as the first.
-Freedom to move in your house
- Long range of up to 300m lets you walk in and outside the house with freedom and without Interrupting your call. Talk hands-free - bringing the caller's voice into the room and letting you get on with things while you chat.
Talk time of up to 12 hours and standby time of up to 120 hours. Great for those long conversations.
-Extra answer machine features
- Save up to 30 minutes of messages and see how many messages you've got displayed clearly on the home screen. Record your own greeting or choose one of ours. Listen to your messages privately through the handset, or play them using the Hands-free speaker. Hear who's calling before you pick up. Choose how many rings you want before the machine picks up. Don't miss important messages when your away from home, access your messages remotely
-Stylish phone
- The modern stylish design makes this phone a great addition to any room, whilst only taking up minimal space. 1.8" full-graphic display provides a more quality look and feel. The excellent blue backlight makes it clear and easy to read
-Even better for the environment
- Eco credentials come as standard with this BT Phone, and it's good to know that the packaging is recyclable and made from FSC certified material. 65% more energy efficient than previous equivalent models
