The New Hub Phone slots neatly into your BT Home Hub 2.0 and gives you UK Evening and Weekend calls at no extra cost - and cheap calls at other times via BT Broadband talk.
It is a fully featured handset which will operate anywhere within the range
of your homehub.
- Broadband Talk (BBT) compatible
- Hi-dS (High definition sound)
- 150 entry shared contacts list
- 50 entry handset contacts list
- Up to 4 numbers per contact
- Handsfree speaker
- 50 number calls list of received and missed calls
- 3 handsets can make simultaneous calls from one BBT number
- Headset port
- Caller ID and Call Waiting supported
- 25 last number redial
- 9 speed dial entries
- 4 line high resolution inverse LCD
- 10 polyphonic ringer melodies
- Ringer volume control
- Secrecy
- Charger can be plugged directly into the mains or into a BT Home Hub 2.0
- Access to BT 1571 service
- Earpiece volume control
- GAP compatible
- Alarm function
- Internal calls
- Call transfer
- Auto talk
- Paging handsets
- Handset power On/Off
- Keypad lock
- Out of range and low battery warnings
- Up to 10 hour talk & 100 hour standby time
- Up to 50m indoor, 300m outdoor range
** Handset must be registered to BT Home Hub 2.0 for all features to be accessible
